ZyWALL USG 200 booting issues
Not able to boot my USG 200, I bought this second hand and tried to reset the device when I lost coms to it.
Now I get the following when booting up:
FLASH: AMD 16M
CF read: device 0 not ready
IDENT command error: 0xf0
ERROR
BootModule Version: V1.12 | 11/17/2009 18:05:22
DRAM: Size = 256 Mbytes
Kernel Version:
ZLD Version:
ERROR
Press any key to enter debug mode within 1 seconds.
Enter Debug Mode
USG 200>
USG 200> atcd 2
ERROR
USG 200> atcd 1
ERROR
USG 200>
USG 200> ?
ERROR
USG 200>
CF device is busy...
FLASH: AMD 16M
ERROR
Kernel Version:
ZLD Version:
ERROR
Device Not Ready
Device Not Ready
Formatted fail
ERROR
J CF device is busy...
FLASH: AMD 16M
ERROR
Kernel Version:
ZLD Version:
ERROR
Device Not Ready
Device Not Ready
Formatted fail
ERROR
errno = ff
ERROR
Now booting kernel in FLASH
ERROR
Linux/PPC load: console=ttyS0,115200 root=/dev/ram init=zyinit ""
Uncompressing Linux...done.
Now booting the kernel
mount: /dev/hda3 is not a valid block device
Check partition table error: 1
Recovering Partition ...
The message; "Check partition table error: 1" continues indefenetly while power on.
What can I do with this?
Hi @einaren,
You can try if it is working after firmware recovery. After you enter debug mode, enter "atkz –f –l 192.168.1.1" to configure FTP server IP address and "atgo" to bring up the FTP server on port 1. Then upload the latest firmware version 330AQU7ITS-WK48-r74988 to ZyWALL USG 200 via FTP.
You can find the details in "Appendix 3. Firmware Recovery" in the release note 330AQU7C0.pdf.
Very good. When I started reading the issue description, I thought this was going to be a case of defective and unrepairable storage device. Good to see that it is a known issue with a known solution.
Hi.
Thanks for the quick reply on this.I tried as described above and also followed the provedure given.
After entering the command "atkz -f -l 192.168.1.1" i run the "atgo" command it starts to boot up. I still get the continues message of "Check partition table error: 1"
I set up a computer with static IP 192.168.1.55 / 24, tried to connect with the bulit in ftp in Windows, but not able to connect to the FW. I've tried to ping the 192.168.1.1 with no reply.
I have also tried to connect using WinSCP ftp with same results.Any ideas to this? Something else I can try?
Einar
Not sure if this makes any difference, but maybe you could try the serial Console port (DB9) and see if the commands issued via the terminal command line (and the responses) behave any differently.
Hi.
Yes that is what I am currently using, only way I can communicate with it, as far as I know in current status.
It is also probably worth mentioning that I had coms with the FW before hitting the reset button. So it seems like something failed during reset of device.1 -
Unless another attempt at firmware recovery or reset procedure can make a difference, I would be inclined to think that there is a chance some actual storage device failure has happened.
Can I use the XMODEM fuction to upload the firmware, or is that for something else?
Good question, I don't know. I defer to the ZyXEL team members for an authoritative answer.
Hi @einaren,
ZyWALL USG 200 is EOL several years ago. If firmware recovery is still not working, we're afraid that it might be hardware issue.
- 395 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 82 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 914 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 415 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
