Modern Authentication (Microsoft and Google) for mail sending
Give the possibility to authenticate through modern authentication to send emails via Microsoft and Gmail addresses.
Hi, basketbros with this answer
Modern email authentication mechanisms are supported by Gmail and Microsoft. Single sign-on (SSO) and multi-factor authentication (MFA) are two technologies made possible by modern authentication that improve security. You may send emails programmatically and authenticate using the Microsoft Graph API. You must register your application in the Azure portal and use the OAuth 2.0 authentication route to receive an access token in order to authenticate.
Both Gmail and Microsoft support modern email authentication mechanisms. Two technologies that modern authentication makes possible are single sign-on (SSO) and multi-factor authentication (MFA). You can send emails programmatically and authenticate using the Microsoft Graph API. To authenticate, you need to register your application in the Azure portal and use the OAuth 2.0 authentication route to receive an access token.
- 603 USG FLEX H Series
- 481 News and Release
