Anyone using the new ATP series can give feedback?
iSpeed
iSpeed Posts: 110 image  Ally Member
edited April 2021 in Security
I'm thinking about starting to roll these out to clients, but having some 2nd thoughts after the 4.32 usg40w / usg60w firmware patch bugs causing local access point to go offline. Anyone have one running and managing access points, etc.?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited January 2019
    @iSpeed
    Regarding to your description,
    I will private message you. Please has a check.
    Charlie
  • iSpeed
    Chalie,  It's ATP200.  Do they have the same firmware issues the USG series had with Wifi Access Points?  I see they are on revision 4.32 patch 1.
  • Zyxel_Charlie
    @iSpeed
    I will private message firmware to you. Please has a check.
    Charlie
  • Pots
    Pots Posts: 1 image  Freshman Member
    Hi Charlie,
    I just get the ATP200 for testing here. Is the anything specil I should pay attention to?
    Want to replace a USG for test and use the its52....
  • Zyxel_Charlie
    @Pots
    If you want to replace the device from USG to ATP, you need to care the below things,
    1. License can not be transferred
    2.Configuration can not be converted
    3.After you register the ATP, the license will be activated together.
    Charlie
