USG FLEX 200 - Blocked URL Keywords to block download of certain files
I thought I could use Blocked URL Keywords to prevent downloading of specific file types (e.g. .exe, .scr, .bat files).
I have a working active Profile for Content Filtering and the Forbidden Web Sites is working for domain names.
However, Blocked URL Keywords doesn't seem to do anything.
For example, to block .scr files, I've tried:
*.scr*
*.scr
/*.scr
*/*.scr
*/*.scr*
The idea is to block access to e.g. www.anydomain.com/path/to/someFile.scr
And I do have "Enable HTTPS Domain Filter for HTTPS traffic" checked.
But nothing's being blocked. Am I doing something wrong?
It can't be done all the Filter for HTTPS traffic does is sees the SNI like hb.yahoo.net it does not see the link and file extension not sure if ssl inspection will help?
So yes you need to enable SSL inspection
Then you can use Keywords in Content Filtering
Hi @aed_alt
Currently, the Content Filter supports an FQDN-based blocked list. Therefore you can configure the website's FQDN www.anydomain.com in the Forbidden Web Sites as a replacement solution.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
