[Release Note] Nebula Switch 100 Series - Phase 8.2 firmware has been released!
Zyxel_Moderator
Zyxel Nebula Switch 100 Series
Release Note
January, 2020
Firmware Version on all models
Zyxel NSW100-10 - V3.00(ABHW.2)C0
Zyxel NSW100-10P - V3.00(ABGO.2)C0
Zyxel NSW100-28 - V3.00(ABHX.2)C0
Zyxel NSW100-28P - V3.00(ABBT.2)C0
New Feature and Enhancements
- *Supports Vendor-ID based VLAN
- *Supports IGMP snooping unknown multicast drop per VLAN
- *Supports MAC address field in IP filtering rule, feature name change from “IP filtering” to “ACL”
- *Supports Access management to control the IP address allowed to access the switch
- Event log enhancement for failure of firmware upgrade
- Added support NETCONF Call Home over TLS on port 4335 (RFC8071)
- When the unknown multicast drop is enabled, unknown multicast to router port will be enabled as well
- Support Management VLAN Control. For security reason, the switch ports can be limited to allow device management VLAN traffic
- Advanced IGMP UI is enhanced and can import channel list for IPTV report
*New features will be able to configure in NCC with new firmware only
Bug Fix
- Enable Spanning tree may cause Switch time delay about 2 minutes a day.
- If there exist special character in user credential when using 802.1X authentication, might cause the Switch crash.
- Specific LLDP packets may cause Switch memory leak.
- Configure management VLAN port setting via local WebGUI, management IP address will be lost.
Nebula Forum Moderator
Release NoteJune, 2017
Zyxel NSW100-10 - V2.00(ABHW.0)C0
Zyxel NSW100-10P - V2.00(ABGO.0)C0
Zyxel NSW100-28 - V2.00(ABHX.0)C0
Zyxel NSW100-28P - V2.00(ABBT.0)C0
New Feature and Enhancements- Add Storm control feature.
- Add Loop guard feature.
- Append a header for Switch statistics section for easier readability.
- Prevent misconfiguration in IP filtering result in NCC disconnection.
- Add Locator LED feature.
- Rename DHCP white-list to DHCP server guard with enhanced network protection mechanism.
- Add Switch list and port list page option.
- Add Cable diagnostic feature.
- Add DDMI for SFP feature.
- Rename Port power cycle.
- Fixed the error message in the bandwidth utilization and uplink usage pages.
- Fixed static IP became 0.0.0.0 and disconnected to DCHP server when changing static IP in ZON utility.
- Fixed classifier configuration is failed to apply and pops up the error message on CLI when modifying the IP filtering rule on NCC.
- Fixed incorrect bandwidth utilization graph in the port detail.
- Fixed NSW is showing offline during unstable connection between NCC and NSW.
- To all users when upgrading Nebula devices, please make sure your device is connected to the control center and internet.
- During the upgrade process (notice the LED will flash in RED rapidly), make sure the power is not inturruped or disabled, in the unlikely event of this happening, you may have to perform the upgrade again.
Nebula Forum Moderator0 - Add Storm control feature.
Release Note
December, 2018
Zyxel NSW100-10 - V3.00(ABHW.0)C0
Zyxel NSW100-10P - V3.00(ABGO.0)C0
Zyxel NSW100-28 - V3.00(ABHX.0)C0
Zyxel NSW100-28P - V3.00(ABBT.0)C0
New Feature and Enhancements- Add Port isolation feature.
- Add IGMP-Filtering, Querier, Leave mode feature.
- Add IPTV report.
- Switch Port detail page is enhanced to display
IGMP counters.
- LLDP enhancement for PoE.
- Add speed/duplex in syslog while port link up.
- Encrypt administrator password on the local device.
- Fixed link up speed is 1G, but NCC shows 9589M.
- Fixed
LLDP information from some other brand devices may cause the connectivity to
NCC is unstable.
The new firmware is available now!
Proceed to upgrade your device now to enjoy the new features as listed above or wait until scheduled upgrade takes place.
Did this add the variable speed fan control as well or was fan speed slightly reduced? I just performed the update. It seems the switch dropped 1 or 2 db but I see nothing in the UI to indicate this. Currently I am only using 2 POE ports, drawing under 10w total and it runs cool even with the lower fan speed.0
Hi @GadgetryTech
The release includes the smart fan design as the variable speed fan control you mentioned. The system will start up at the lowest fan speed, and during operation, fan speed will be adjusted linearly based on system temperature.
So basically this is determined by the device itself.
BTW, the NebulaFlex switches are less noisy by hardware nature since the maximum fan speed has lower rpm.
Cheers
Thank you. I heard the fan drop a little in speed when it rebooted after the update. At least I know I'm not crazy. Are the plans to for more insight on hardware such as sensor thermals and fan speed (rpm). The switch is currently drawing less than 10w so I wonder if the fan speed could be dialed back even more. Thanks!0
Hi @GadgetryTech,
Thanks for your advice, I will post a new topic in Idea section for "Current temperature and Fan speed of Switch can be shown on Nebula CC".
Please note that the smart fan feature only supports on NSW200 series and Hybrid Switch due to hardware limitation. Also the fan speed depends on the temperature of Switch, not how many PoE power Switch send.
Hope it helps.
Release Note
March, 2019
Zyxel NSW100-10 - V3.00(ABHW.1)C0
Zyxel NSW100-10P - V3.00(ABGO.1)C0
Zyxel NSW100-28 - V3.00(ABHX.1)C0
Zyxel NSW100-28P - V3.00(ABBT.1)C0
IGMP snooping report proxy enhancement.
- 603 USG FLEX H Series
- 481 News and Release
