Anyone using the new ATP series can give feedback?
Chalie, It's ATP200. Do they have the same firmware issues the USG series had with Wifi Access Points? I see they are on revision 4.32 patch 1.0
Hi Charlie,I just get the ATP200 for testing here. Is the anything specil I should pay attention to?Want to replace a USG for test and use the its52....0
@Pots
If you want to replace the device from USG to ATP, you need to care the below things,
1. License can not be transferred
2.Configuration can not be converted
3.After you register the ATP, the license will be activated together.
Charlie0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
