Zyxek USG VPN with OpenSwan - can you share working configurations?
grokit
grokit Posts: 18 image  Freshman Member
edited April 2021 in Security
I seem to have considerable issues to get a VPN between a Zyxel USG 300 and OpenSwan VPN Server on CentOS to work.
I think I have tried dozens of combinations. The main issue is to find the right encryption/authentication settings between the two VPN servers.
I would appreciate, in case one of you has a working setup, you could share that with me.
Thanks a lot
Dan
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @grokit
    Regarding to your request,
    you can check below as your reference.
    Example on USG:
    Example on OpenSwan:
    # basic configuration
    config setup
      charondebug="all"
      strictcrlpolicy=no
      # uniqueids = no
    # Add connections here.
    conn Zywall 110
      type=tunnel
      keyexchange=ikev1
      authby=secret
      left=192.168.111.20
      leftid=192.168.111.20
      leftsubnet=172.16.1.0/24
      right=192.168.111.51
      rightid=0.0.0.0
      rightsubnet=192.168.1.0/24
      ike=aes-sha-modp1024!
      esp=aes-sha-modp1024!
      keyingtries=0
      ikelifetime=1d
      lifetime=8h
      dpddelay=30
      dpdtimeout=120
      dpdaction=restart
      auto=route
    Charlie
  • grokit
    Thanks @Zyxel_Charlie
    I got it running in the meantime, but with different setup. It seems to be a bit unstable, though.
    I will try your solution as well. I hope it's better :-)
    Dan
