Amazon fire blocked by USG 60 W?
Good morning,Sorry to take so long in coming back - yes the topology is ISP------Draytek 2925AC ) ) ) ) Amazon Fire.However over the last three or four weeks the Amazon Fire has found its way out to the interweb.There has been an intervening update of the USG 60 W so perhaps something has changed there or perhaps Amazon have changed something.Either way, all is well just now.Perhaps more importantly I'm trying to understand the logs as to what is being blocked and what is being allowed to come through to our system - is there an easy guide to what is what here?I ask because occasionally web destinations I used to be able to get to with the Draytek I cannot get to using the USG 60 W and I've been trying to check out what exactly is being blocked.BestAndy0
@Dovetail_MD
If USG blocked device, you can check Category to know which function block device, and then check Source IP and Destination IP to infer which rule was hit cause blocking occur.
Charlie0 -
@Zyxel_Emily @Dovetail_MD
i'm not sure, but Entertain and other Streaming services required IGMPv3 and my last information is, that a ZYWALL 40/60 (W) modell is not supporting IGMPv3.
In my case, i'm not able to use T-Entertain (IP-TV) behind a ZYWALL 40/60 (W) until IGMPv3 is embedded in a further Firmware.
Regards
Christian
@ChristianG
Regarding to IGMPv3,
you can enable IGMPv3 in CLI interface and apply the command as below (assuming that lan1 is where you want to enable)
After that you can do wireshark /packet capturing from the interface, you will see the version it uses:
Charlie0 -
@Zyxel_Charlie
thanks for the good news =)in 2017/2018 was the statement "not supported"
Good to know, it's possible to enable IGMPv3
Regards
Christian
Okay - so doing as you suggest I find that all the blocking is being done by Security Policy Control - and looking at that does not take me much further reallyAgain is there a fool's guide to what this does?0
@Dovetail_MD
Can you screenshot the log page for check further?
Currently, we do not have guide which described the details of log message, however, if you face or some information cannot understand, we can discuss on the forum.
Charlie0
- 220 Nebula Ideas
- 602 USG FLEX H Series
- 480 News and Release
