VPN100 Routing Policy conflict problem
We have got two different Internet from different providers and we are using for Teams, Skype and Google VOIP only WAN2.
Rule looks like:
User (any) Incoming(lan1) Source(any) Destination(Microsoft) Next hop(wan2_ppp)
We have got some Microsoft teams problem but we have configured the policy correctly. When I do connectivity test everyting looks fine.
To test I added only my client routing policy route:
User (any) Incoming(lan1) Source (pc-alban_mic) Destination(Microsoft) next hop (wan1_ppp)
but my PC can not access to Microsoft IP's.
any idea?
Do you have the rules in order with the rule source PC above the other rule?
source pc-alban is above than General user rule
What happens if Destination is any?
destination any blocking all traffik except intern LAN
I don't follow what is it you want to allow out on WAN1_ppp?
have you allowed DNS?
we have setuped a routing rule. The Microsoft Teams and Skype traffic should WAN2_PPP, the other traffic using WAN1_ppp (http, etc)
but we could not find the reason why Microsoft teams calls freezing or why we are getting "Poor Network" messages from Microsoft Teams (BW Usage is under control)
to check the WAN1_ppp teams performance I created a new rule. The others will be use Teams on WAN2 as usual except me. Now When I make this rule I can not access above IP ranges and teams does not work on me.0 -
I'm not sure how Microsoft Teams and Skype works if it relays between everyone or tries to connect to each others IP's but you might of missed a subnet and thats why your having problems
you may try FQDN
*.teams.microsoft.com
*.skypeforbusiness.com
still same, no ping to any microsoft IP
This might be normal its getting Teams working is what you want
Not sure what teams your using but this is what I found
FQDN list
*live.com
*live.net
*microsoft.com
*skype.com
*skypeforbusiness.com
*teams.microsoft.com
*windows.com
I'm not able to test video or mic as don't have them but think you need to allow UDP 3478 -3481
and on PC run IPconfig /flushdns
Hello @alban_mic
Could you please provide the device config file to us via private message for further checking? We will send you a private message later, so please check your inbox. Thank you.
See how you've made an impact in Zyxel Community this year!
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
