SSL VPN with secuextender not working
I have setup an SSL vpn on my USG40 following this tutorial.
https://support.zyxel.eu/hc/en-us/articles/360001390774-How-to-create-an-SSL-VPN-Tunnel-via-SecuExtender-software-
I can establish a connection with the Secu-extender, but I can't reach a device on my LAN1 network, even the SSL pool gateway 192.168.200.1.
If I check the assigned IP on TAP Adapter look strang3e...
Firmware V4.32(AALA.0) / 2018-07-12 17:13:23
Secure extender 4.0.3.0
SSL GATEWAY: 192.168.200.1
SSL POOL IP: 192.168.200.100 - 192.168.200.120
Remote network LAN1: 10.0.1.0/24
Best Answers
I got the same issue and found this FAQ.Set subnet in "Assign IP Pool" and the issue is resolved.1
Thank you !jasailafan said:I got the same issue and found this FAQ.Set subnet in "Assign IP Pool" and the issue is resolved.0
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
