IPSecVPN - Cannot ping remote IP range
I have a Zyxel 1100 at SiteA and a USG 220 at SiteB.
I used the wizards to congifure my site to site IPSecVPN and it's working in that it came up immediately on both sides.
My problem is I cannot ping any IP addresses on either side. I can't even ping the Zyxels on each side.
Both devices are new and I have not cluttered the things with guesses at fixes, but I feel like I'm missing something simple like a policy or a check mark somewhere.
I did not add any additional security policies. I just let the wizards do everything, and that's where I am now. I am unable to ping IP addresses behind each firewall.
Can someone tell me please what I missed?
Thank you
So, this is working now. What did I do you may ask? Nothing!
I built out the IPSec VPN connections in each firewall and it did not work.
I posted here.
I went in this AM, deleted my two IPSec VPN connections (one out of each firewall) and then added them back.
It's working as expected now.
Posted reply in error
Devices need to allow ICMP inbound on there firewall for one.
you maybe need a routing rule above any other rules like LAN1 next hop WAN with a rule above LAN1 destination subnet of IPs over the tunnel and next hop VPN tunnel
security policies like LAN1 to VPN zine and VPN zone to LAN1
@CRP0499 three major mistakes may cause the traffic not to go through the tunnel.
Please refer to this article for further troubleshooting first, thanks.
Thank you James. I do believe I understand the article. What I would like clarity on is I have TWO IPSec VPN tunnels in the 1100. The first tunnel I set up is working as expected. Traffic is flowing and pings are passing.
When I set up the second tunnel, I cannot ping across it.
My trace route shows my pings first hop as the first vpn tunnel, so, I'm thinking I need routes to tell traffic where to go.
With just one VPN tunnel, things work great. When I add the second vpn tunnel, that's where things begin to break down.
I posted here.
Do you have different IP subnet on different sites such that you don't have 192.168.1.0/24 on on another site or enabled interface which such a subnet?
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
