USG FLEX 500H - web access does not work correctly
DomCHFR
hi,
I cannot access my firewall via the web interface. I can log in but then I have hourglasses running in all my dashboard windows. I restart the firewall from nebula and then everything works again. unfortunately after a few days the problem recurred. This doesn't seem to affect its operation. Internet access works. I receive the logs. I have the latest firmware. 1.10.
An idea ?
Thanks for your help.
best regards
Dom
Hi @DomCHFR
The WebGUI (dashboard) loading issue has been address and fixed in V1.10WK05 firmware.
You may have a try the firmware and verify if it helps in your case.0 -
On USG FLEX 200H with V1.10(ABWV.1)ITS-24WK05-M3737 this still happens about once a week. The only way to fix it is to reboot.
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
