Force Outgoing IP to WAN
I have been using a PEPLINK 310 for the past 5 years. And just upgraded my connection speed and need to upgraded to hardware that can handle the speed.
I purchased the Zywall 310 and for the life of me, can't force an outgoing IP address to use a specific WAN port.
I have three WAN ports,
WAN1 has 5 IP's (interface ge1)
WAN2 has 1 IP (interface ge2)
WAN3 has 5 IP's (interface ge3)
I have setup and Address Object call HP35 (which is a HOST with a private IP address of xxx.xxx.xxx.35)
Under routing I created a rule
What is it that I'm missing?
Do I have to have a schedule defined, if I want this all the time?
Thank you in advance.
Well, then from the policy route rule you set.
It should translate the source IP of HP35 to ge1 interface IP and sent out from ge1.
5
If all the WAN IPs are in the same subnet.
Then you cannot assign it to different WAN port.
The arp learning of default gateway ip address will make issues which flapping on different WAN ports.
They are not in the same subnet.
WAN1 is 50.xx.xx.xx
WAN2 is 63.xx.xx.xx
WAN3 is 67.xx.xx.xx0 -
5 -
Well that was frustrating. But I believe the issue has been resolved. The PC in question, had two IP numbers assigned to the same card.
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
