USG40 Mac based VLAN
2»
    PeterUK Posts: 4,264 image  Guru Member
    edited March 2024
    MAC based VLAN has its uses but for you only need 802.1Q VLAN like this
    But if you have a simple AP then the above will not help but Mac based VLAN is not security anything on a simple AP level before a switch with Mac based VLAN can see other devices.
    So if thats the case you should get a better AP the can do SSID to tag VLAN like NWA1123-AC PRO or WAX510D
  • IWAT
    IWAT Posts: 15 image  Freshman Member
    Hi Peter
    I bought a NWA90AX_Pro and i have configured it for VLAN60, it seems that ist doesn't reach the USG40 with the correct VLAN.
    Installation:
    USG40 <-> GS1900 <-> XGS1930 <-> NWA90AX_Pro
    How can i see where it stucks?
    Br
    GS1900_VLAN_Config1.jpg GS1900_VLAN_Config2.jpg GS1900_VLAN_Config3.jpg NWA90AX_Pro.jpg USG_40_Config1.jpg USG_40_Config2.jpg XGS1930_VLAN_Config1.jpg XGS1930_VLAN_Config2.jpg
  • IWAT
    It works!
    The Problem has been that on Switch GS1900 and XGS1930 the Ports haven't been tagged for VLAN60.
