Maybe DNS issue with vlan on WIFI
Chrysler
Chrysler Posts: 3
edited May 2024 in Wireless
I did some network segmentation last week.
Vlan 1 is still the server and printer vlan
Vlan 2 is the computer vlan
Everything's OK when I'm wired.
But when I'm connected by wifi on vlan2 (ssid with pvid 2) I have GPO problems or I'm told there's a dns problem.
To test this, I created two rules on my USG that open all traffic between vlan 1 and vlan 2.
NSLOOKUP finds my domain
GPUPDATE tells me "name resolution failure on the current domain controller". Note that everything works when I'm on a wired connection.
I've been working on it for 3 days without finding the problem.
Similarly, I can't print on wifi. It tells me that the RPC server is unreachable, whereas if I switch to wired it works.
Need help...
Translated with DeepL.com (free version)
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    Hi @Chrysler,
    Could you help to confirm the port of your switch, which connects to the AP, is a VLAN 2 member and tagged out?
    " I can't print on wifi. It tells me that the RPC server is unreachable, whereas if I switch to wired it works." May I know if you mean you cannot ping any device on WiFi?
    Zyxel Melen
  • Chrysler
    Chrysler Posts: 3
    Yes,
    The port of the AP have the vlan 1 untaged (by default) and vlan2 taged.
    SSID is on the vlan2, i receive the good dhcp address, i can access to servers who are in vlan1.
    —> When laptops are connected on the WLAN network i can't print on the printer (who are in vlan1). But, i can ping the printer and i have access to the http website of the printer.
    But all it works when the laptop is wired connected.
  • Zyxel_Melen
    Hi @Chrysler,
    Thanks for your information. To investigate your issue, I would like to clarify some questions with you:
    1. Your model and the current firmware version.
    2. Your configuration. Can you navigate to Maintenance > File Manager > Configuration File to download the "Start-up config" file?
    3. Could you help to change the SSID to VLAN 1 and test? I would like to know if VLAN 1 works?
    Thanks in advance.
    Zyxel Melen
