flex 500H Ipsec_VPN remote access with strongswang doesn't work
azampi
azampi Posts: 3
Has anyone a successful configuration that works with strongswan android and flex 500h. Configuration created with wizard doesn't work ?
  • azampi
    azampi Posts: 3
    Hi Peter thanks a lot I changed Interface with my Dyndns and it works. I have an older router VPN100 on this router I could define multiple VPN connection. With this new one new definitions will overwrite existing definitions. Ipsec VPN remote access.
    PeterUK Posts: 4,169 image  Guru Member
    edited March 2024
    Not tested that on android yet tested on windows, is the interface setting for VPN the android connects to the 500H correct is the phone from WAN to zywall or LAN to zywall? Did the VPN Configuration Script Download install the Certificate on your phone?
    edited March 2024
    Just tested here with a 200H with strongswan it works you need to import the SSWAN Configuration Script to phone
  • azampi
    azampi Posts: 3
    Hi Peter thanks for your response. Yes i downloaded the script and imported to my Galaxy s24 Ultra svan app. There are not many thing that you can make wrong !! . It is a connection mobile internet Zywall. You see in the log "not trusted RSA Public Key found for USGFLEX…." I think that my 500H firmware has still some issue. May be I was too fast to install this device !!. What kind of client are you using under windows ?
    well my other I have test strongswan on my Sony android  phone and it works note that if you use interface your phone connect to and the IP of your WAN IP changes then the Script will be wrong so check in strongswan settings
  • azampi
    azampi Posts: 3
