flex 500H Ipsec_VPN remote access with strongswang doesn't work
Hi Peter thanks a lot I changed Interface with my Dyndns and it works. I have an older router VPN100 on this router I could define multiple VPN connection. With this new one new definitions will overwrite existing definitions. Ipsec VPN remote access.
Not tested that on android yet tested on windows, is the interface setting for VPN the android connects to the 500H correct is the phone from WAN to zywall or LAN to zywall? Did the VPN Configuration Script Download install the Certificate on your phone?
Just tested here with a 200H with strongswan it works you need to import the SSWAN Configuration Script to phone
Hi Peter thanks for your response. Yes i downloaded the script and imported to my Galaxy s24 Ultra svan app. There are not many thing that you can make wrong !! . It is a connection mobile internet Zywall. You see in the log "not trusted RSA Public Key found for USGFLEX…." I think that my 500H firmware has still some issue. May be I was too fast to install this device !!. What kind of client are you using under windows ?
well my other I have test strongswan on my Sony android phone and it works note that if you use interface your phone connect to and the IP of your WAN IP changes then the Script will be wrong so check in strongswan settings
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
