USG FLEX 200H - How to disable SecuReporter?
bbp
bbp Posts: 70 image  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
I'm receiving SecuReporter reports every week by email, even though SecurReporter is disabled.
I have also looked in Nebula but I couldn't find any setting to disable weekly reports.
Config:
/ vrf "main" secureporter "enabled" "false"
/ vrf "main" secureporter app-patrol "enabled" "false"
/ vrf "main" secureporter anti-malware "enabled" "false"
/ vrf "main" secureporter threat-protection "enabled" "false"
/ vrf "main" secureporter content-filter "enabled" "false"
/ vrf "main" secureporter sandboxing "enabled" "false"
/ vrf "main" secureporter reputation-filter "enabled" "false"
/ vrf "main" secureporter traffic-log "enabled" "false"
/ vrf "main" secureporter interface-statistics "enabled" "false"
/ vrf "main" secureporter app-statistics "enabled" "false"
/ vrf "main" secureporter ike "enabled" "false"
/ vrf "main" secureporter "upload-filesize" "10"
/ vrf "main" secureporter "upload-interval" "600"
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @bbp & @morininet,
    To disable the SecuReport and its notification, please navigate to SecuRepoter > your org & site > Menu > History > Report > Report settings to edit.
    First step:
    Second step:
    Zyxel Melen
  • Zyxel_Stanley
    edited April 2024
    Hello @bbp,
    You can have a check if you have enabled SecuReporter function from your NCC setting.(Configure > Site Setting > Reporting)
    If it still doesn't help, please drop private message to me for further check in your case.
  • bbp
    Thank you for the reply, Zyxel_Stanley.
    I have only Nebula base pack and I don't have that option in Configure > Site Setting > Reporting
    I have disabled all alerts in Configure > Alert settings
    • The email I receive are SecuReporter Summary Reports (screenshot bellow) Screenshot 2024-04-01 150525.png
    • How can these emails be disabled?
  • morininet
    morininet Posts: 1 image  Freshman Member
    Is there a solution to this Question?
  • Zyxel_Melen
    First step:
    Second step:
    Zyxel Melen
  • bbp
    Thank you @Zyxel_Melen
