USG FLEX 200H - How to disable SecuReporter?
I'm receiving SecuReporter reports every week by email, even though SecurReporter is disabled.
I have also looked in Nebula but I couldn't find any setting to disable weekly reports.
Config:
/ vrf "main" secureporter "enabled" "false"
/ vrf "main" secureporter app-patrol "enabled" "false"
/ vrf "main" secureporter anti-malware "enabled" "false"
/ vrf "main" secureporter threat-protection "enabled" "false"
/ vrf "main" secureporter content-filter "enabled" "false"
/ vrf "main" secureporter sandboxing "enabled" "false"
/ vrf "main" secureporter reputation-filter "enabled" "false"
/ vrf "main" secureporter traffic-log "enabled" "false"
/ vrf "main" secureporter interface-statistics "enabled" "false"
/ vrf "main" secureporter app-statistics "enabled" "false"
/ vrf "main" secureporter ike "enabled" "false"
/ vrf "main" secureporter "upload-filesize" "10"
/ vrf "main" secureporter "upload-interval" "600"
Hi @bbp & @morininet,
To disable the SecuReport and its notification, please navigate to SecuRepoter > your org & site > Menu > History > Report > Report settings to edit.
First step:
Second step:
Zyxel Melen0
Hello @bbp,
You can have a check if you have enabled SecuReporter function from your NCC setting.(Configure > Site Setting > Reporting)
If it still doesn't help, please drop private message to me for further check in your case.
Thank you for the reply, Zyxel_Stanley.
I have only Nebula base pack and I don't have that option in Configure > Site Setting > Reporting
I have disabled all alerts in Configure > Alert settings
- The email I receive are SecuReporter Summary Reports (screenshot bellow)
- How can these emails be disabled?
Is there a solution to this Question?0 -
First step:
Second step:
Zyxel Melen0 -
Thank you @Zyxel_Melen
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
