USG110 iptv setup
Please i have usg110 and i am using it for iptv from my internal tuner gateway and at the same time to hook it up with my isp for internet .can some help me with configuration. Do i need to create 2 vlan for the iptv and the internet , say vlan10 for iptv and vlan 4 for the internet?
Please i am novice and need help
Need to enable IGMP on the interfaces. Here is an example.
https://support.zyxel.eu/hc/en-us/articles/360004093659-IPTV-with-multicast-and-IGMP-USG-ATP-VPN0
https://support.zyxel.eu/hc/en-us/articles/360004093659-IPTV-with-multicast-and-IGMP-USG-ATP-VPN0 -
Jasailfan
thank you very much
had seen the link but i am seeing enable IGMP ON WAN and Enable IGMP on the Lan . I am not using ISP to provide the IPTV source, i have a media source on the LAN so i should use the Enable IGMP on the Lan only ?
If i use Enable IGMP on the Lan , is there any need for setting up firewall policy rule?
please can somebody help me with how to configure vlan on the USG110. What IP address should i use for the Vlan. I am using DHCP server on my USG110
Does it means i have start from the Enable IGMP on the Lan AS i have my internal IPTV SERVER and ignore Enable IGMP on WAN?
Do i need to create a Vlan on the based port p6 and enable DHCP on it ? I have my own iptv server should i add it to the DNS setting?
Please i really need a help
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
