Firmware for a es-2024
I am a new user of this forum and have a few es-2024 managed switches in my company network. I would like to update the firmware to the latest available version. I know these are older or old switches but still working good. I have been searching for the firmware files but can not find anything other then an attachment 390fw.zip in this forum.
Which does not load and the switch returns a firmware upgrade error.
My question is : where can I find/download a correct firmware file for an es-2024 ?
Thank you,
Roelof
Hi @Roelofth
Could you please clarify which specific model you are using? Is it the ES-2024A or the ES-2024PWR?
If you are looking for the firmware for the ES-2024A, you may refer to this thread:
If you're looking for the latest firmware for the ES-2024PWR, you may refer to this thread:
As the ES-2024A/ES-2024PWR switches have reached the EOL (End of Life) status, we suggest exploring our current switch offerings here: for optimal performance and support.
Kay
Hi @Roelofth
Kay
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
