site-to-site VPN works, but no ping/traffic
StefanZ
StefanZ Posts: 202 image  Master Member
First Comment First Answer Friend Collector Second Anniversary
edited April 2024 in USG FLEX H Series
Trying to migrate the pinned up VPN connections from my F50 to the F200H.
Remote is a F200.
Set up the connection with the same parameters, worked on the first try.
Connection is steady – but no traffic is possible.
IKEv2 PSK
Phase 1
DES/MD5
AES128/SHA1
3DES/SHA1
DH2
Phase 2
AES128/SHA1
3DES/SHA1
DES/SHA1
DH2
local is 192.168.1.0/24, remote is 192.168.0.0/24
I cannot ping anything – neither from F200H, nor the F200 – added two Security Policies on both sides to allow pings back/forth. I can see the packets leaving in the log of the sender, but nothing is received.
It's in the LAN zone of the F200H
    I would suggest using V1.10(ABWV.1) as newer has problems
    I will do some testing here
  • StefanZ
    There is a newer firmware? 👻
    My current firmwares:
    USG FLEX 200H V1.10(ABWV.1) 2023-11-20 15:22:57
    USG FLEX200 5.37(ABUI.2) 2024-01-24 02:43:53
    USG FLEX50 5.37(ABAQ.2). 2024-01-24 02:40:10
    edited April 2024
    In my setup I have USG60W
    VLAN4093 192.168.252.0/23
    with tunnel FLEX200H Ge3 192.168.254.10/29 as WAN to LAN2 192.168.254.9/29 on USG60W
    VLAN47 on FLEX200H 192.168.255.32/28
    To ping 192.168.255.40 from 192.168.253.1 a routing rule on USG60W might be needed
    incoming VLAN4093
    destination IP19216825532
    next hop VPN Tunnel
    Gwtoflex200H_local2
    Then a Policy Control rule
    On Flex200H you may need to do the same thing depending on your setup but the VPN remote IP Policy looks to be checked before routing rules but next hop would be the interface the tunnels goes out on along with Policy Control rule from the tunnel so in my case from GE3 to VLAN47 but recommend you enter a source address subnet which GE3 would be from a VPN zone.
    ping back to 192.168.253.1 also works fine
