USG40 and DynDNS
Poppen
Poppen Posts: 5
Hi!
I've a DynDNS account with an FTP domain directed to a Zyxel USG40 firewall. Behind the firewall there is two Synology Diskstations with each fixed IP in Interface "lan1", provided by DHCP from the USG40. I can't get the USG40 to update DDNS without a "Fail" each time, seems to be no matter the settings. Account at DynDNS are OK, but what settings should I use and are correct ??
  • Poppen
    Poppen Posts: 5
    No one ? 😔
    PeterUK Posts: 4,272 image  Guru Member
    Don't have DynDNS but hae No-IP and Dynu with User custom settings
    Are you using DynDNS as DDNS type and set on a WAN interface?
  • Poppen
    Poppen Posts: 5
    Hi !
    The USG40 are connected to Internet through the WAN-interface P1. Then the LAN1-interface P2 are connected to a Gigabit switch and all other computers and Synology Diskstations are connected to that switch. The USG40 are DHCP-server but all connections are forced to fixed IP by their MAC-adress. I could access the Diskstations inside the LAN1-interface.
    I used to have another Zyxel firewall (Zywall 2 ??) and got that working, but I think I used Port redirection somehow to get the FTP call (with a port #) from outside to pass the Firewall to the correct IP for respectively Diskstation. But that old firewall died and I can't see what I did then to get it working.
    When I check DDNS status on the USG40 it says "Updating" and then always changes to "fail"
    show DDNS settings you have put in
  • Poppen
    Poppen Posts: 5
    set interface to WAN1 with IP address to auto unless I got the wrong idea you normally want DDNS to update what WAN IP you have or if you do want to update DDNS to that IP set interface to WAN1
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    capture packets to see the negotiation when you updated DDNS.
  • Poppen
    Poppen Posts: 5
    Hi again!
    No WAN1-interface still fails while updating DDNS. When I try to access the FTP-link from outside (internet) I end up to the USG40 admin login. The FTP-request for the Diskstation IP (192.168.1.37) don't pass the firewall. I'm too newbie to capture packets etc, more of an Plug & Play guy :-)
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 975 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Poppen ,
    Greeting Forum, Please change firewall FTP port to other.
    if the issue still, we can have quick remote session. I'm avaialble at 09:00~17:00 Taiwan time.
    Thank you
