after ssl connect with secuextender, client cannot see lan1
  • AndersO
    AndersO Posts: 2
    image  Freshman Member
    AndersO said:
    USG110 - Firmware 4.32 - Same issue. Windows 10, TAP driver (version 9) stays on default IP, and not range of VPN.
    Firmware received, and all problems solved. Thanks @Zyxel_Charlie for great support!
  • Sammy_D
    Sammy_D Posts: 1
    Hi @Zyxel_Charlie,
    pleae can you send me also the new firmware - no ip with USG110 4.32 (AAAA.0).
  • Ondrej
    Ondrej Posts: 5
    First Comment Sixth Anniversary
    Hi.
    We have same problem on a USG20W-VPN FW:4.32(ABAR.0), could you send me the firmware.
    4.0.2.0 works fine..
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034
    image  Zyxel Employee
    @Sammy_D and  @Ondrej
    I will private message the firmware to you. Please has a check.
    Charlie
  • Puzzle
    Puzzle Posts: 4
    First Comment Sixth Anniversary Nebula Gratitude
    edited January 2019
    We have the exact same issue.
    It only occurs on Windows 10 clients.
    @Emily or @Charlie: Could you send me the patched firmware as well?
    We operate a ZyWALL 110.
    When can we expect the release of a firmware that corrects this issue?
  • Zyxel_Charlie
    @Puzzle
    Regarding to this case,
    the solution will be included in firmware 4.33 which will release around the end of Jan.
    However, I will private message firmware to you. Please has a check.
    Charlie
  • kyssling
    kyssling Posts: 107
    First Comment First Answer Friend Collector Sixth Anniversary
    image  Ally Member
    Hi, please  can you send me also the new firmware, if solving problem :
    https://businessforum.zyxel.com/discussion/2071/secuextender-4-0-3-0-for-windows-failed-to-access-zywalls-lan
    Very Thanks Vaclav
  • Mark_Manning
    Mark_Manning Posts: 2
    Hi, I'm having exactly the same issue with 4.0.3.0 firmware on a USG110, could you please send me the updated firmware?
  • MarkW
    MarkW Posts: 2
    We have the same problem on a USG110 FW:4.32 could you send me the firmware update please?
  • Zyxel_Charlie
    @MarkW
    Charlie
