Setup Standalone Mode - WiFi 7 | BE1100
Hello community. I'm trying in vain to get into standalone mode for the initial setup. I don't need NCC. I'm using a 5G modem from ZTE in bridge mode and the AP is connected behind it. The Zyxel WiFi with the 4 digits of the MAC address is displayed. However, it doesn't allow a connection. Connection via Ethernet is possible. However, I don't know the internal IP address for the standalone configuration and http://1.1.1.1 or setup.zyxel.com don't work. The AP keeps flashing green/orange (continuously). How do I get to the setup page or to the IP address of the AP? Thank you for your advice.
Hi @Hansiiiuuu ,
Based on your description, it appears that your NWA130BE access point has obtained an IP address from the ZTE's DHCP server. To know the NWA130BE's IP, you can utilize the Zyxel ZON tool to scan for it. Note that the IP address of the laptop and the NWA130BE must be on the same subnet.
On the other hand, you can check the ZTE’s DHCP table for its IP details.
Zyxel_Judy
Addresses such as:
192.168.1.1 or 192.168.1.2 or 192.168.1.254 also do not work.The device was added to NCC using a QR code. However, no local IP address was not assigned.
Hi @Hansiiiuuu ,
Zyxel_Judy
- 603 USG FLEX H Series
- 481 News and Release
