GS1200-5 upgrade stuck to upgrade failed
..and try again.
Tried, a few times.
First tried the latest 2.00(ABKM.3)C0, then "downgrade" to V2.00(ABKM.2)C0
Downloaded V2.00(ABKM.1)C0, but i have not tried it yet.
I have read all the questions about this problem, tried all the methods (except curl), but no working solution found.
No matter if i reset the switch. It is the same page "upgarede failed" again and again.
Linux OpenSuse Firefox & Chromium with or without addons, security settings on and off.
Directly, no VPN and the file from the product page.
I'll try upgrade from a windows computer and how it went.0 -
.. and it worked 🙂
I renamed the file as firmware.bin as did someone else here when upgrading some version of GS1200.
That maybe pointless, but thought maybe there is some magic in it.0 -
And of course copied the file to the root C:\
Hi @Veijo
I'm glad to know that you solved it.
Please let us know if there is anything else we can help with.
Nami
There seems to be a problem with the upgrade procedure under Linux: I recently flashed 2 of them (from Linux + Firefox or Chromium, as well as from Android) which remained in "upgrade failed" mode. Fortunately, Zyxel sent me 2 back as I didn't have any Windows available. So I didn't dare upgrade any more.
Thanks Veijo for the info, I'll try to find a Windows to recover the switches.1 -
xfs, unregistered windows 10 is enough. I have a spare laptop with win10 and used it to upgrade.
U can download windows iso from
https://www.microsoft.com/en-us/software-download/windows10ISO1
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
