Configure VLAN on LAG for switch GS1900 series
Hi, not see LAG on VLAN static setup page…what's wrong?
v4.70(ACDS.3)
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @MatteoMuzzolon2000,
    The firmware version you gave is mapping to GS1915-24EP, which is the GS1915 series. GS1915 series is different from the GS1900 series. It does not have the LAG VLAN option, please configure the VLAN setting on the ports you set LAG. Below is an example.
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
