Can't get DDNS Certificate to work with SecuExtender VPN Client
PeterUK
PeterUK Posts: 4,175 image  Guru Member
USG FLEX 200 V5.37(ABUI.2)
SecuExtender VPN Client_IPSec_SSL_VPN_7.7.40.019
I have a Certificate for something.ddns.net and for testing point at 192.168.255.237 logs show it built but then disconnects
But if I make a self-signed Certificate it works
If I drop the encryption for windows default that can be changed
Phase 1 3DES/SHA1 DH2
Phase 2 AES256/SHA1 PFS none
Import my something.ddns.net Certificate setup too windows VPN built in Client that works so why can't the SecuExtender VPN Client_IPSec? I think Its got something to do with intermediate Certification authorities that the SecuExtender VPN Client does not have? I tried exporting that to SecuExtender VPN Client but it didn't work.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @PeterUK
    Thank you for reporting this case to us. Could you please send me the certificate with the DDNS domain name via private message? We want to check the certificate content. Thanks.
