Re-enable the web-GUI of a FLEX 500H with ssh terminal
Hi, I should reactivate the web-GUI interface of a Flex 500H
if I try to check the status from ssh terminal with commands
show state vrf main http-server server
show state vrf main http-server secure-server
both result disabled.....
I tried to re-enable them from ssh with commands
edit running
vrf main http-server server / vrf main http-server secure-server
save
but they are always disabled even after the reboot
where am I wrong?
Thank you
Best Answers
Hi @qsystem,
usgflex200h running config# vrf main http-server secure-server enabled true
usgflex200h running config# commit
usgflex200h running config# vrf main http-server server enabled true
usgflex200h running config# commitResult:
usgflex200h running config# show state vrf main http-server secure-server
secure-server
enabled true
port 443
usgflex200h running config# show state vrf main http-server server
server
enabled true
port 80
..0 -
Hi @qsystem,
You need to enter “copy running startup” to save settings to startup configuration before you reboot the device.
usgflex200h running config# copy running startup0
Hi @qsystem,
secure-server
enabled true
port 443
server
enabled true
port 80
..0 -
Hi @qsystem,
usgflex200h running config# copy running startup0 -
Hi @Zyxel_Emily
perfect !!! the problem has been solvedthank you
Regards0
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
