USG40W Wifi wont start, AP list edit hangs
I've done a bout of firmware updates bringing us up to V4.32. On restarting everything popped up fine, except the wifi. Its just a simple single SSID to lan1. I can examine all wifi assets except the AP List, the edit box hangs. I edited the startup config replacing all the wifi configuration with defaults, I then and added the wifi setup via the GUI. Same result. Any suggestions?
Hi @AirfoxI have tried it on my device, but it is not happened on my device.Does the symptom still exist after reboot your device?Or any specific setting in your configuration?0
Hello there,
I have rebooted several times, with no change.
No real complex configuration, 3 x IPSec VPS's and 1 x SSL VPN.
Lan1 is DHCP with 172.16.1.0/24 subnet.
Wifi is from this configuration guide which has worked fine for 3 years, http://www.dslreports.com/forum/r29904778-Setting-Up-Wifi-USG40W
I noticed the new system-default.conf is 71K, my startup-config.conf is only 24K. I am wondering if there are some settings that are missing from my startup-config.conf which is causing the issues.
@Airfox
After following the configuration guide, the issue did not occur on my lab.
If you use other browser, the issue still happen?
Can you private message your configuration for check further?
Charlie
I have tried with Opera, Firefox, Chrome, Vivaldi and Edge. All have the same result, the edit dialogue box hangs.
I will PM the startup-config.conf to you.0
- 588 USG FLEX H Series
- 476 News and Release
