GS1200-8 https for web management
eolo
eolo Posts: 35 image  Freshman Member
Is the activation of https for the GS1200-8 web interface planned in the future? It looks identical to the XGS1210-12, but https is missing.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @eolo
    We appreciate your question regarding HTTPS support on the GS1200-8. This model currently does not feature HTTPS for web management, unlike the XGS1210-12, which is equipped with this capability. This difference stems from the specific design and target use case of each model.
    Nami
  • Zyxel_Nami
    Hi @eolo
    Nami
  • eolo
    I believe that in 2024 web access to the console should be mandatory in https, for any device, however thank you for the reply.
