ZLD 5.38
besides not getting an Emailnotification that the 5.38 is out since first of april i found this section in the changelogs:
[Feature Change]: Not support certificate signed using weak hashing
algorithm (Md5 or SHA1)
Does this also concern the rootcertificates?
For end-entity certificates, always use a stronger algorithm (e.g., SHA-2) for signing.
Regularly update your system’s root certificate store to ensure proper trust validation. I think you can reference https://docs.digicert.com/en/certcentral/certificate-merge fruits-vulnerabilities/weak-hashing-algorithm.html0 -
This is exactly why i asked if this is change will also concern Rootcertificates (ie own CA-Certificates). I'd rather not change it on hundreds of computers/phones outside of mdm-capabilities 😉
- 215 Nebula Ideas
- 566 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
