USG Flex 700 Port Forwarding
I have a Zyxel USG 700 and desperately trying to get Port Forwarding to my Server or with other words: Trying to Access my Server from WAN (e.g Domain/IP).
I think my ZyWall is allowing incoming traffic to the server ip but not letting anything out.
Has anyone a Plan to get it working, it don’t know how to fix the Problem.
My Network setup:
GE01 = Starlink (Failover)
GE12 = Fiber (Main Internet) (Don't Ask why GE12, I will be changing it in a few Days)
GE14 = LAN Outgoing to Switch/Gateway
Your Secure Policy is incorrect.
Correct rule be like:
Source zone : WAN , Source: Any
Dst znoe : LAN , Dst: Synology IP
Unplug GE1 and test again
Ahh, Sorry, I should note you have rule1.
I think you need to design a for "DNS-Net" zone.
Rule1: from"DNS-Net" zone not any
Thanks for your comments.
I Got it working, almost. Its Working 3-4 Hours and then without changing any Setting it just stop forwarding the Ports.
I have to manually go into the USG Nat Settings, change the Internal IP from the Working Gateway/Device to a IP Address that isn't connected, wait about a minute, change it back and then, the port forwarding just works again. I don't understand why..
Can anyone help with this Problem?
GE01 got disconnected and will be offline for 1-2 Months
try the rule as 1:1 NAT
Okay, I´m trying.
so I’m back. It worked definitely longer, a little bit over a day. But now, same problem happend again and got fixed by changing the destination IP to a non existing client and back to the normal IP.
what if policy control rule for destination is any?
I have setup a port test on my FLEX200 not the same model as you I see if I run into any problems
I changed it to any. See if it helps, thank you in advance.
That would be great, thank you. Functions should be the same, i think
Problem still exist. I dont know why, but its annoying me VERY much..
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
