GS1200-8 Confirm feature port isolation
AndyR
AndyR Posts: 3
Hello Guys,
I'm looking for a switch with port isolation and I would just like to confirm if the GS1200-8 does have this feature? Thank you.
Best Answers
    edited April 2024 Answer ✓
    The User's Guide shows  port isolation seems when enabled you can set each port to be a uplink
  • AndyR
    AndyR Posts: 3
    Thanks Peter… wasn't sure if 'v' was a tick or not…
    yes the v would mean the given model has that function
  • AndyR
    AndyR Posts: 3
  • AndyR
    AndyR Posts: 3
    Thanks!
