GS1900-24hp firmware & SNMP
Hi all,
I have a GS1900-24HP switch, the current firmware is V2.60(AAHM.1)|06/17/2020
Is there a later version that I could use, if so can you outline the steps for upgrading the firmware for me.
The other question I have is regarding SNMP due to qualys vulnerabilities, would it be better to disable SNMPv1/2c, if it was disabled what is the outcome, or can it be removed?
Thanks all
Hi @Jules52
You can download the latest firmware for GS1900-24HP using the following link:
Latest firmware: 2.70(AAHM.3)C0
Regarding your query about SNMP vulnerabilities, we'd appreciate more details on the specific vulnerabilities you're referring to. Could you provide us with the CVE number?
Since the GS1900-24HP has reached EOL status, we recommend exploring the GS1900-24HPv2 or our current switch offerings here: for optimal performance and support.
Kay
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
