Security policy FQDN
Alex_91
Alex_91 Posts: 27  Freshman Member
edited April 18 in Security
by following this Microsoft link to allow access the Outlook App to Exchange OnPrem:
I see that you need to enable fqdn to allow access.
Am I wrong or Zyxel firewalls not resolve the IP class?
I add this roule:
sometimes rule not working
    PeterUK Posts: 3,460  Guru Member
    edited April 22 Answer ✓
    Can FQDN resolve IP subnet?
    No I FQDN can lookup the IP's of a DNS name bbc.co.uk
    151.101.0.81
    151.101.64.81
    151.101.192.81
    151.101.128.81
    You can do *bbc.co.uk for WILDCARD for subdomain by DNS that happens LAN to WAN for the IP's it gets
  • WJS
    WJS Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Those addresses are server need to access which means this is outgoing traffic.
    I thought you need a rule is LAN → WAN , dst: AppOutlook
  • Alex_91
    Let's leave aside for the moment the question of whether it is needed (for incoming or outgoing access).
    Example: outlook.cloud.microsoft -> 13.107.6.152/31 + 13.107.18.10/31 + …
    or is it really necessary to specify the various subnets manually?
  • WJS
    It can. It works with FQDN objects.
  • Alex_91
    from specific firmware or what?
    I can confirm that if I enter the various IPs manually in the rules (13.107.6.152/31, 13.107.18.10/31, 13.107.128.0/22, ...) the application works.
    If I leave the FQDNs alone (outlook.cloud.microsoft, outlook.office.com, outlook.office365.com) the app doesn't work.
  • WJS
    FQDN object should work with now alive appliance.
    But sounds like you have FQDN object which mean your firmware should support this feature.
    Maybe try the latest firmware ?
    151.101.0.81
    151.101.64.81
    151.101.192.81
    151.101.128.81
Security Highlight
