USG20 Firmware do not match SHA256 and MD5 sums...
DCO
DCO Posts: 2
Anyone else having this issue?
5.38(ABAQ.0)C0 sums fail to match listed checksums on site. https://www.zyxel.com/global/en/support/download?model=usg20-vpn
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    IMVHO checksum should be verified on .bin file. not on .zip file.
  • DCO
    DCO Posts: 2
    Thank you for the reply. Unfortunately, same outcome.
    s@XDCOL-PC11T6EZ:~/Downloads/iso/fw/zyxel/USG20/5.38/firmware$ cat SHA256
    C1D1AE529619558A6E17138F10601A152D0012E62A5F0433B3702459BE0625FA 538ABAQ0C0.bin
    s@XDCOL-PC11T6EZ:~/Downloads/iso/fw/zyxel/USG20/5.38/firmware$ sha256sum -c --ignore-missing SHA256
    538ABAQ0C0.bin: FAILED
    sha256sum: WARNING: 1 computed checksum did NOT match
    sha256sum: SHA256: no file was verified
