Modifying BWM rule lockup
PeterUK
USG FLEX 200H V1.20(ABWV.0)
Testing by www.youtube.com on UDP port 443 for the of a 4K video
I make one rule with the following
Incoming Interface ge4 LAN
Outgoing Interface ge2 WAN2
Service Object UDP443
Download Limit 20Mb (yes not enough but part of the test)
Upload Limit 4Mb
Priority 7
You then watch a 4K video like
Make sure you force to 4K and uses UDP port 443 for the video
It will buffer AS this is happening change the rule above for Download Limit to 30Mb this then locks up the FLEX H
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
