Content filter on ATP800 not working
Posts: 57  Ally Member
First Comment Sixth Anniversary
Hello, the content filter seems to not be working correctly.
By blocking categories such as social networks or pornography, you can access it without problem.
I have also activated the DNS content filter and I can also access it even if it is in blocked categories.
Any idea what is happening?
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
«1
  • Posts: 3,744  Guru Member
    edited April 2024
    Set “action when category server is unavailable” to block
    move rule to top of the list
    Might a VPN or proxy be in use by the client?
  • Posts: 17  Freshman Member
    Hello Zyxel, what is happening, I have the same problem as of Wednesday, April 17, I thought it was some bad configuration of mine, but in the same way my USG1100 fails, the content filter does not work. I hope they resolve it soon. This problem only happens with Edge and Chrome, Firefox still respects the Content Filter
  • Posts: 928  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Pedroj , @YanShadowGT ,
    Greeting Forum, Could you share your config file by Private message ?
    Thank you
  • Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Try to disable if you are using Chrome
    chrome://flags/#enable-tls13-kyber
  • Posts: 57  Ally Member
    Hello, I don't understand very well, but this morning everything is working without changing settings?
    What can be the motive?
    Hi @WJS
    Thank you for your support, you have solved the problem with the content filter, I hope Zyxel solves this incompatibility with this TLS 1.3 encryption. Since Google says that this option will be temporary and will not allow it to be disabled in future versions.Thank you again!!!
  • Posts: 52  Ally Member
    First Answer First Comment Friend Collector Fifth Anniversary
    We found the same problem on the Zyxel USG310 and USG Flex 50 routers. I didn't test any other models yet, these are the ones that we had reports that the content filter isn't working on. I'm guessing we have over a 100 routers with content filter subscription on them. So we need an update to fix this as trying to disable TLS 1.3 on each computer at every company is not a practical solution.
    edited April 2024
    Even if Zyxel fix the problem it may only be for current models and not EOL ones
    The DNS Content filter should work if you don't use dns over HTTPS
    Hi @electsystech
    We're aware of the issue from TLS1.3 Kyber,
    We're working on it.
    Thank you
    edited April 2024
    We sent a request into Zyxel to have HQ look into this. The content filter policies and DNS content are no longer working. This is a significant problem and hopefully a router firmware patch can be released quickly.
Welcome!
Welcome!
