Content filter on ATP800 not working
Hello, the content filter seems to not be working correctly.
By blocking categories such as social networks or pornography, you can access it without problem.
I have also activated the DNS content filter and I can also access it even if it is in blocked categories.
Any idea what is happening?
Set “action when category server is unavailable” to block
move rule to top of the list
Might a VPN or proxy be in use by the client?
Hello Zyxel, what is happening, I have the same problem as of Wednesday, April 17, I thought it was some bad configuration of mine, but in the same way my USG1100 fails, the content filter does not work. I hope they resolve it soon. This problem only happens with Edge and Chrome, Firefox still respects the Content Filter
Hi @Pedroj , @YanShadowGT ,
Greeting Forum, Could you share your config file by Private message ?
Thank you
Try to disable if you are using Chrome
chrome://flags/#enable-tls13-kyber
Hello, I don't understand very well, but this morning everything is working without changing settings?
What can be the motive?0 -
Hi @WJS
Thank you for your support, you have solved the problem with the content filter, I hope Zyxel solves this incompatibility with this TLS 1.3 encryption. Since Google says that this option will be temporary and will not allow it to be disabled in future versions.Thank you again!!!
We found the same problem on the Zyxel USG310 and USG Flex 50 routers. I didn't test any other models yet, these are the ones that we had reports that the content filter isn't working on. I'm guessing we have over a 100 routers with content filter subscription on them. So we need an update to fix this as trying to disable TLS 1.3 on each computer at every company is not a practical solution.
Even if Zyxel fix the problem it may only be for current models and not EOL ones
The DNS Content filter should work if you don't use dns over HTTPS
We sent a request into Zyxel to have HQ look into this. The content filter policies and DNS content are no longer working. This is a significant problem and hopefully a router firmware patch can be released quickly.
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
