New added NAT rule don't work till you reboot USG FLEX 200H
PeterUK
USG FLEX 200H V1.20(ABWV.0)
Found this problem when trying to redone ports for Input Director by a gateway-less setup each NAT rule needed a reboot of the FLEX for it to work.
Hi @PeterUK
Thank you for reporting this case to us. Please allow us to reproduce the issue and investigate it further. Thank you.
I have the same problem on the FLEX 500H - the new NAT rules do not work until I reboot the device
Hi @ZdenekB
May we know which firmware version you are currently using? If this issue recurs, could you please assist us by collecting the diag-info log (Maintenance > Diagnostics > Diagnostics > Click 'Collect Now') at that time. Thanks.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
