need interface rate limiting
PeterUK
PeterUK Posts: 4,741
image  Guru Member
edited April 2024 in USG FLEX H Series
Not yet tested BWM but to really test this interface rate limiting is needed.
Also be able to limit by Mb and Kb
«1
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,408
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    image  Zyxel Employee
    Hi @PeterUK
    OK, thank you😉. We are investigating this issue for you. Once we resolve it, you can continue testing the Bandwidth Management (BWM) feature.
    image  Guru Member
    This plus I want to rate limit a bridge in and out interfaces too
  • Zyxel_Jeff
    OK, got it. Thanks.
    image  Guru Member
    also currently not able to rate limit bridge traffic
    image  Guru Member
    edited October 2024
    When might we see rate limiting interfaces and rate limiting of the bridge interfaces (not the bridge itself but the interfaces for the bridge) please?
    image  Guru Member
    edited February 2025
    With the new UI for bridge will there be a added Egress rate limiting like this with BWM?
    old models can Egress rate limit interfaces in a bridge so I'm hoping the same for FLEX H
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,762
    Hi @PeterUK ,
    Could you share which specific ZLD model supports Egress rate limiting on individual interfaces within a bridge?
    In my experience with ZLD devices, rate limits are applied to the entire bridge rather than to individual interfaces within the bridge.
    Are you asking for H series devices support rate limiting for bridge or individual interfaces within a bridge?
    Zyxel_Judy
    image  Guru Member
    Hi Judy
    So on old ZLD like on VPN300 I have Ge1 (WAN1) and Ge8 (DMZ) that are in a bridge br1 I set Egress rate limiting per each interface like so.
    Screenshot 2025-02-21 083039.png Screenshot 2025-02-21 083101.png Screenshot 2025-02-21 083158.png
    Due to V1.31 UI changes per interfaces in the bridge only show in the bridge but I would like to be able to rate limit total limit going out the interfaces in the bridge. Just checking this will be possible in the upcoming firmware.
    Note: about the old ZLD the rate limiting of interface in a bridge must 1st be removed from the bridge set rate limit then add back to bridge
  • Zyxel_Judy
    Hi @PeterUK ,
    Currently, there are no plans to implement the egress bandwidth function for uOS devices. If you want to set bandwidth limits for the interface, we recommend using the BWM feature instead.
    Zyxel_Judy
    image  Guru Member
    Well I'm sure there are plans to implement the egress bandwidth other wise the new uOS is a bit pointless.
    Also I did try using BWM for interfaces WAN1 and DMZ that are in a bridge and it did not rate limit that way so can that be looked at in the mean time please?
