Modifying BWM rule lockup
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited April 2024 in USG FLEX H Series
USG FLEX 200H V1.20(ABWV.0)
Testing by www.youtube.com on UDP port 443 for the of a 4K video
I make one rule with the following
Incoming Interface ge4 LAN
Outgoing Interface ge2 WAN2
Service Object UDP443
Download Limit 20Mb (yes not enough but part of the test)
Upload Limit 4Mb
Priority 7
You then watch a 4K video like
Make sure you force to 4K and uses UDP port 443 for the video
It will buffer AS this is happening change the rule above for Download Limit to 30Mb this then locks up the FLEX H
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    edited April 2024 Answer ✓
    Hi @PeterUK ,
    We already fix the issue
    Please find the Inbox, I have provdied DF for you.
    Thank you
  • Zyxel_Kevin
    Hi @PeterUK ,
    Thanks your feedback, I'm able to replicate issue.
    We're checking on it.
    Thank you
  • Zyxel_Kevin
    Hi @PeterUK ,
    Thank you
