HA PRO on FLEX H SERIES ?
I don't see the availability of HA PRO in FLEX H SERIES specs.
It is supported or it will be supported in next future?
Today i saw that my 2 VPN100 are End-of-Life…
Best Answers
Hello @RGB
Thank you for your inquiry. The Device HA feature will be supported in Q4 of 2024 for the USG Flex H series models. Thank you.
Hi @RGB
Based on your requirements, we recommend choosing the USG Flex 500 or USG Flex 700 to deploy Device HA. Currently, if you purchase the brand-new USG Flex series models, you will receive the default Gold Security Pack license. Thank you.
Hello @RGB
Thanks Jeff.
Between the current FLEX series (no H), and ATP, which of these 2 series will have the longest life for security updates?
Hi @RGB
- 441 Beta Program
- 292 Service & License
