USG60W - no DHCP on WiFi after firmware upgrade
@Steve84
Regarding to this case,
I tested the wifi with firmware v4.33 without any issue.
Since you updated the firmware 4.20->4.33, it is a 4 major versions jump, in this case we will suggest users to upgrade from 4.20-> 4.25->4.30->4.31->4.33 or it may have some unexpected result.
Charlie0 -
OK, so can you give me a link to download old firmwares, my zyxel allow me to download 4.31,3.32 or 4.33 only. Thank you0
Hallo,
i am not sure if every "administrator" of a USG is aware that 4.25 and 4.30 are "major versions".
Maybe it should be indicated more clearly in the Release notes or the Firmware upgrade page what are major version upgrades and how to do it correctly.
Thx
Wolfgang
Steve84, If the config is not too complex I would probably document and then hit the reset button with 4.33 installed and then reprogram. Charlie what do you think?0
@Wolfgang
Normally we will suggest users to upgrade their firmware version by version to avoid any unexpected result. However, we can also put the upgrading version suggestion in our formal release note in the future release.
@iSpeed
I agree with you and actually this is what we just suggested Steve84.
Charlie0 -
Thank you for your answers, I'll reset my USG0
Hi, news for my problem. I tried to downgrade to firmware 4.31 end then the USG asked me if i wanted to upgrade to the last firmware. Before to reset it, i said yes… and all works nicely again !
Mysteries of firmware upgrades
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
