USG Flex 700 Port Forwarding
Nico_L
Nico_L Posts: 6
edited April 2024 in Security
I have a Zyxel USG 700 and desperately trying to get Port Forwarding to my Server or with other words: Trying to Access my Server from WAN (e.g Domain/IP).
I think my ZyWall is allowing incoming traffic to the server ip but not letting anything out.
Has anyone a Plan to get it working, it don’t know how to fix the Problem.
My Network setup:
GE01 = Starlink (Failover)
GE12 = Fiber (Main Internet) (Don't Ask why GE12, I will be changing it in a few Days)
GE14 = LAN Outgoing to Switch/Gateway
Bildschirmfoto 2024-04-16 um 21.22.55.png Bildschirmfoto 2024-04-16 um 21.41.40.png Bildschirmfoto 2024-04-16 um 21.42.16.png
«1
  • WJS
    WJS Posts: 156  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Your Secure Policy is incorrect.
    Correct rule be like:
    Source zone : WAN , Source: Any
    Dst znoe : LAN , Dst: Synology IP
    PeterUK Posts: 3,751  Guru Member
    Unplug GE1 and test again
  • WJS
    Ahh, Sorry, I should note you have rule1.
    I think you need to design a for "DNS-Net" zone.
    Rule1: from"DNS-Net" zone not any
  • Nico_L
    Nico_L Posts: 6
    edited April 2024
    Thanks for your comments.
    I Got it working, almost. Its Working 3-4 Hours and then without changing any Setting it just stop forwarding the Ports.
    I have to manually go into the USG Nat Settings, change the Internal IP from the Working Gateway/Device to a IP Address that isn't connected, wait about a minute, change it back and then, the port forwarding just works again. I don't understand why..
    Can anyone help with this Problem?
    GE01 got disconnected and will be offline for 1-2 Months
    try the rule as 1:1 NAT
  • Nico_L
    Nico_L Posts: 6
    so I’m back. It worked definitely longer, a little bit over a day. But now, same problem happend again and got fixed by changing the destination IP to a non existing client and back to the normal IP.
    edited April 2024
    what if policy control rule for destination is any?
    I have setup a port test on my FLEX200 not the same model as you I see if I run into any problems
  • Nico_L
    Nico_L Posts: 6
    I changed it to any. See if it helps, thank you in advance.
    That would be great, thank you. Functions should be the same, i think
  • Nico_L
    Nico_L Posts: 6
    Problem still exist. I dont know why, but its annoying me VERY much..
