Unable to automatically reconnect to the 6GHz SSID
For anybody else having similar issues, I was able to fix this by changing 6GHz channel selection from auto to manual and then trying different channels and then turning off wifi and then turning it back on until I found channels that seemed to work better with my phone and other devices.
EDIT: I thought it was working, but same effect. Initially connects to 6GHz, but then after leaving and coming back it never reconnects.
2 -
- Ensure your device supports Wi-Fi 6E. Older devices typically only support 2.4GHz and 5GHz bands. Check your device specifications or settings to confirm it supports the 6GHz band.
Thanks, my device does support 6GHz band, and it will connect briefly at times.
- 430 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 354 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 82 Security Highlight
