How to override-direct-route
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited April 2024 in USG FLEX H Series
Not listed in UI but by SSH
edit running
vrf main routing policy-route override-direct-route true
commit
copy running startup
to disable
vrf main routing policy-route override-direct-route false
This option is helpful for some setups if you don't want to use Allow Asymmetrical Route
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK ,
    Yes, you may find settings that are not available in the GUI through some CLIs. We will keep implement the GUI and try to cover option which ZLD have.
