NAT ports over a bridge
PeterUK
PeterUK Posts: 4,427 image  Guru Member
edited January 2024 in USG FLEX H Series
Things I really want want the new H models to do that say my USG40 can do which is to change port coming in to the bridge to map to others.
I hope this will be possible in updates to come
    edited April 2024
    Was hoping I can get some feedback if at some point I can NAT ports through a bridge on the FLEX200H
    2.2.2.2:4444 > My IP:30000 >NAT> 2.2.2.2:4444 > My IP:9999
    thanks
    V1.21(ABWV.0)ITS-24WK35-0813-240800592
    Solved with the help of Jan as the Flex H does it differently
    So instead of WAN to DMZ for the ports Its Br0 to DMZ for the policy control rule and on the NAT rule incoming interface its br0
