No traffic in VPN IPSec Site-to-Site
2»
  • [Deleted User]
    [Deleted User] Posts: 0 image  Freshman Member
    The third party gave me instruction to use local policy 10.9.230.144/29 , while their local (my remote) is 172.16.0.0/12 ,
    @PeterUK
    "as it is you can't source NAT /24 from /29 1:1 SNAT"
    So what should I do in my case?
  • mMontana
    mMontana Posts: 1,499 image  Guru Member
    @PeterUK thanks for correcting me.
    PeterUK Posts: 4,622 image  Guru Member
    edited April 2024
    we don't know what IP from 10.9.230.145 – 10.9.230.150 they want you to source from try 10.9.230.145 as SNAT
  • [Deleted User]
    Done, no change.
    Let's filter out the possible issues, if I put a computer on 10.9.230.0/24 subnet I don't need a SNAT, correct?
    you say its 10.9.230.144/29 255.255.255.248
    so if you make a LAN subnet your side with that 10.9.230.145/29 and a PC on 10.9.230.146 you don't need SNAT in the tunnel and it should work
  • [Deleted User]
    An update, I disabled the SNAT and Routing on the USG, put a pc on IP 10.9.230.146 and the VPN correctly works.
    Now I would be curious to know why the routing from computers on 192.168.1.0/24 subnet doesn't work. If I keep these settings on the USG, but add on a linux pc this routing:
    Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
    172.16.0.0  10.9.230.254   255.240.0.0     UG    0      0        0 enp5s0
    Shouldn't I be able to connect?
    Because the other end is expecting  10.9.230.145 – 10.9.230.150 when it see 192.168.1.0/24 it will get to its gateway and not down the tunnel.
    so we now know 10.9.230.146 works so with SNAT by the VPN tunnel should work
  • [Deleted User]
    It works!
    Thanks a lot for your precious support.
